Concerning logs after updating firmware on ATP500 in HA config
mattb
mattb Posts: 6 image  Freshman Member
Friend Collector Third Anniversary
edited April 2024 in Security
I just updated firmware to 5.37(ABFU.2) in HA config. After the firmware applied to the standby router and took the primary role, the passive router was updated. After reboot, it finally finished syncing and says success. But the logs show the following. Do I need to manually fix the startup config on the "passive" (formerly primary) router?
Tue Apr 9 16:24:44 2024 Enter Stand_By mode
Tue Apr 9 16:24:44 2024 Enter Passive mode
Tue Apr 9 16:24:45 2024 Start to synchronize with active device
Tue Apr 9 16:39:04 2024 Verify missmatch: Active(encrypted-keystring [redacted] Update ZySH Startup Configuration has failed. Error code: 2
retry: 1
retry: 2
Tue Apr 9 16:39:05 2024 Verify missmatch: Active(encrypted-keystring [redacted] Update ZySH Startup Configuration has failed. Error code: 2
retry: 3
retry: 4
retry: 5
Tue Apr 9 16:39:05 2024 Device HA udpate fail(ZySH Startup Configuration).
Tue Apr 9 16:39:05 2024 Synchronize complete
  • Zyxel_Cooldia
    HI @mattb,
    Please help me to type following command on standby device, and sent the result to me in PM.
    Router> show device-ha2 sync summary
    Router> show device-ha2 trace-log
