How do I "fix" the message "invalid preshared key"?
Trying to set up the guest account - each time I select "save" i get a message stating "invalid pre-shared key". What am I missing/need to do? (Please - in VERY basic simple steps !!!)
so I have the modem/router detailed in the first photo.
the second photo shows the _guest account “entry point”.Third photo is the resultant screen.
Fourth photo is the message I get after selecting save (happens if I change the password or leave it as the default provided)
Maybe you can change the password to a number or text.
Or try to obtain the latest firmware from your ISP or retailer.
Hello @Swampy
If you want, there is some later firmware for VMG1312-T20B at https://support.zyxel.eu/hc/en-us/articles/4403361365778-Zyxel-CPE-Devices-Firmware-Advanced-Downloads-Firmwares-and-other-resources which could take you to V5.30(ABSB.5)C0 .
Kind regards,
Tony
Downloaded and installed the latest firmware - still coming back with "Invalid pre-shared key"
Hello @Swampy
Ok.
Apparently under Network Setting > Wireless > Guest/More AP > Edit you can generate a network password automatically, which might help you.
It should I hope generate a valid password as a valid pre-shared key.
* see screenshots below.
The device is probably also being particular about what characters are in the key, so automatic generation should help with this too.
Kind regards Tony
- 434 Beta Program
- 2.6K Nebula
- 172 Nebula Ideas
- 404 USG FLEX H Series
- 296 Security Ideas
- 1.5K Switch
- 43 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 4K FAQ
- 83 Security Highlight
