USG60 can not login after select standby frameware 4.31 and press reboot
andrewngow
I can not login to USG60 after select the "standby" v4.31. (my running version is 4.25) and press reboot..reboot successful. I can connect the usg60 but only can not login with the user as admin and the password when using v4.25.
@andrewngow
Since each firmware partition has own configuration, can you try to update the v4.31 firmware on running partition directly?
Before you update the firmware, please remember to backup your configuration file.
Charlie0
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
