Zywall USG FLEX Series, ATP Series - V5.38Patch 0 Firmware Release
Zyxel_Melen
Zywall USG FLEX Series, ATP Series Release Note
April 2024
Firmware Version on all models
(Click the hyperlink to find the firmware file directly)
| FLEX Series | Download link | ATP Series | Download link |
| FLEX50 | V5.38(ABAQ.0)C0 | ATP100 | V5.38(ABPS.0)C0 |
| FLEX50W | V5.38(ABAR.0)C0 | ATP100W | V5.38(ABRW.0)C0 |
| FLEX50AX | V5.38(ACGB.0)C0 | ATP200 | V5.38(ABFW.0)C0 |
| FLEX100 | V5.38(ABUH.0)C0 | ATP500 | V5.38(ABFU.0)C0 |
| FLEX100W | V5.38(ABWC.0)C0 | ATP700 | V5.38(ABTJ.0)C0 |
| FLEX100AX | V5.38(ACFN.0)C0 | ATP800 | V5.38(ABIQ.0)C0 |
| FLEX200 | V5.38(ABUI.0)C0 | ||
| FLEX500 | V5.38(ABUJ.0)C0 | ||
| FLEX700 | V5.38(ABWD.0)C0 |
New Feature and Enhancements
S=Standalone mode, C=Cloud mode
| New Feature and Enhancements | S | C |
| 1. [eITS#230800065, 230801657, 240100888]: ADP allow list support extend to include protocol anomaly. | V | - |
| 2. Add last update time on SecuReporter Allow list table. | V | - |
| 3. System protection log category change to system. | V | - |
| 4. Not support certificate signed using weak hashing algorithm (Md5 or SHA1). | V | - |
| 5. Cannot set the password to "1234" after the first login for "admin" account. | V | - |
| 6. Adjust USG20(W)-VPN & USG FLEX 50 default SSL VPN active user to 15. | V | - |
| 7. Update AP version to V6.70(.2) | V | - |
| 8. The WBE660S is fully supported in this release. Introducing the WBE660S, a NebulaFlex Pro AP powered by cutting-edge WiFi 7 technology that comes with 3 management modes: standalone, controller managed and Nebula cloud managed modes. | V | - |
| 9. Added more supported countries for WiFi 6E and WiFi 7 (6Ghz) models. | V | - |
| 10. Boost GUI efficiency by optimizing handling of extensive access points and client data influx. | V | - |
| 11. DNS Content Filter support Google/ YouTube/ Microsoft Bing Safe Search. | - | V |
| 12. Support change to a different ISP (WAN fallback). | - | V |
Bug Fix
| Bug fix | S | C |
| 1. eITS#230600172 a. Change wording of outing column in SNAT flow for Remote Access VPN. | V | - |
| 2. eITS#230900510 a. Fix: VPN won’t rollback to the primary link when the primary link comes up. | V | - |
| 3. eITS#231000331 a. Fix: Hotspot clients connectivity Issue. | V | - |
| 4. eITS#231001935, 240201158 a. Fix: Certificate synchronization issue in HA Pro scenario. | V | - |
| 5. eITS#231001977, 231201224 a. Fix: Shorten the booting up time in certain conditions. | V | - |
| 6. eITS#231002090, 240201323 a. Fix: CAPWAP no response and AP disconnect from APC. | V | - |
| 7. eITS#231002128 a. Fix: External IP Black list update fail on IPv6 address. | V | - |
| 8. eITS#231002194 a. Fix: Device does not response to https/ssh/console access when using FQDN object in BWM. | V | - |
| 9. eITS#231100767 a. Fix: ssl inspection doesn't work as expects due to abnormal memory usage. | V | - |
| 10. eITS#231101460 a. Fix: Remove "MOVE" icon in ADP policies. | V | - |
| 11. eITS#231101571 a. Fix release notes pop-up window resize issue. | V | - |
| 12. eITS#231200559 a. Fix: Configuration synchronize issue when device ha role swap. | V | - |
| 13. eITS#231200687 a. Enhancement: Cache memory recycling mechanism. | V | - |
| 14. eITS#231200814 a. Fix: The tftp traffic can't get files from the tftp server through the VPN tunnel. | V | - |
| 15. eITS#231201080 a. Fix: Web Authentication portal can’t popup when browsing the page via https. | V | - |
| 16. eITS#231201250 a. Fix: SSH accessibility issue to XGS4600 when going through firewall. | V | - |
| 17. eITS#231201383 a. Fix: LLDP packets can’t be sent out. | V | - |
| 18. eITS#240100074 a. Fix: BWM malfunctioning when using vlan interfaces. | V | - |
| 19. eITS#240100387 a. Fix: speedtest server select doesn’t work. | V | - |
| 20. eITS#240101503 a. Enhancement: Add cli command to support “year” information in syslog. | V | - |
| 21. eITS#240200401 a. Fix: Add "Responder Only" CLI for IPsec VPN. b. crypto map [CRYPTO_NAME] responder-only c. crypto map [CRYPTO_NAME] no responder-only | V | - |
| 22. eITS#240200927 a. Fix: speedtest sometimes cannot get the result. | V | - |
| 23. eITS#240200968 a. Fix: 2FA OTP mail can only be sent to 1 email account. | V | - |
| 24. eITS#240201103 a. Fix: rip/ospf can’t work on VTI interface. | V | - |
| 25. eITS#240201114 a. Fix: Content Filter Profile icon status incorrect. | V | - |
| 26. eITS#240300167 a. Fix: Wording adjustment. | V | - |
| 27. eITS#240300451, 240301211 a. Fix: Device reboots unexpectedly. | V | - |
| 28. eITS#231201567 a. Fix: pppoe connection issue when multiple pppoe instances are configured | - | V |
| 29. eITS#240201203 a. Fix: Device becomes unresponsive after losing connection to Nebula server. | - | V |
| 30. Common vulnerabilities and Exposures: ZLD5.38 Patch0 is no longer vulnerable to the following CVE References: -CVE-2023-48795 | V | V |
Please refer to the Download Link for more details.
Zyxel Melen
sad to see VPN Series EOL🙁
2
- 236 Nebula Ideas
- 6.8K Security
- 737 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 91 About Community
- 119 Security Highlight
