HTTPS Domain Filter enabled cause web pages to delay loading
PeterUK
PeterUK Posts: 4,446 image  Guru Member
edited April 2024 in USG FLEX H Series
USG FLEX 200H V1.20(ABWV.0)
bypassing DNS lookups to not go by FLEX due to problems now even when not in use by Policy rule if HTTPS Domain Filter is enabled web pages get a delay when loading which V1.10 was faster.
Cleared browser cache With HTTPS Domain Filter is enabled
Cleared browser cache With HTTPS Domain Filter is disabled
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 981 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @PeterUK ,
    I took https://www.grc.com, for testing , here is my result.
    with HTTPS domain filter : 3.137sec.
    without HTTPS domain filter: 3.614 sec.
    There is no apparent different in my site.
    I verified by wireshark ( Statistics → Capture File properties) and find the display packets time spend.
    Could you share your packets to me by Private message .
    Thank you
    edited April 2024
    I think the problem is to do with routing Zywall to a given interface VLAN443 with many WAN interface that was not a problem in V1.10 I test that later today and send you the packets
    update seems I can't make this happen now😖
