Been seeing this error
PeterUK
PeterUK Posts: 4,272 image  Guru Member
edited April 2024 in USG FLEX H Series
most on routing and NAT rules moving them about
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 975 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @PeterUK,
    We will have fix in next FCS. 1.30.
    Thank your feedback.
    Kevin
«1
  • Zyxel_Joshua
    Zyxel_Joshua Posts: 62 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security 5 Answers First Comment Friend Collector
    Hi @PeterUK ,
    What's the firmware version.
    And please post the result of the following CLI:
     > diff running startup
    edited April 2024
    its on the new firmware
    USG FLEX 200H V1.20(ABWV.0)
    login as: admin
    Keyboard-interactive authentication prompts from server:
    | Password:
    End of keyboard-interactive prompts from server
    0> diff running startup
    0>
    would you like me to send you the config? its over 200KB
  • Zyxel_Kevin
    Hi @PeterUK ,
    I tested those action in your 200H, but there's no error message pop up
    1)Took Polciy Route #2 move to rule 3
    2)Took NAT Rule#6 move to rule5
    Please kindly correct me if I have wrong steps.
    Thank you
    edited April 2024
    I did remove some rules so that might have something to do with it I was seeing the error for a rule move bottom to top
  • Zyxel_Kevin
    OK, so the error message is gone.
    Please kindly inform me when you see it again.
    Thank you
    edited April 2024
    Have made it happen again under a new error
    I now have 28 routing rules If try to move bottom rule to top I now get error
    on reboot with 28 rule you can move 28 to 1 but add one more rule for 29 to 1 you should get error or add mor rules move them to the top until you do run into this error
  • Zyxel_Kevin
    I moved rule19 (the last) to the top.
    But there's no error. Could you try again within 04-18 firmware.
    Thank you
    edited April 2024
    No you need more rules over 28 to make this happen and I only just got it on 04-18 firmware
    I will make some more rules and let you test
    Ok move 29 to the top
  • Zyxel_Kevin
    Thank you ,
    Now can see issue in your site. Please help stay the symptom for us.
