L2TP VPN server - AD authentication
Hi
Trying to set up VPN for clients using my AD server for authentication on a Flex200.
Everything works, but how can I limit access to only one AD group?
Under advanced setting in Nebula for my AD server the is a "Group Membership Attribute:". This field is not anywhere in documentation so I don´t know if it can be used to setting the AD group. I have tried to enter the CN= string but it does not work. (I know it works if the firewall is not managed by Nebula).
Anyone?
Hi @AndersW,
At present, it is not supported in the current design of NCC.
We will raise it as a feature request for future evaluation.
Really?😮
Yes this is a complete lack of a simple feature.
The nebula setup is missing the ability to chose the “External User Group” when setting up “Remote access VPN”
This is possible when the device is onprem managed.
There is a workaround. Create a Security policy to disable a specific AD group. But then you must maintain two AD groups (allow and deny). This is VERY bad workaround.
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
