EX5601-T0 and MPro Mesh App
F4RN_Chris
in Home Router
I'm trying to use the MPro Mesh App on my Android Phone with a EX5601-T0 router
Both are on the same WiFI network.
The app complains that it "Cannot Connect to the WiFi router".
Any suggestions on how to get the app to connect?
OK - Fixed this myself. Doh.
You have to enable the Mesh on router before the app can connect with it.
Mesh is enabled on the Network Setting - Wireless Menu, then select the "Mesh Tab"0
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 299 Service & License
- 482 News and Release
