ATP 200 does not send email for 2FA VPN authentification
I'm using ATP 200 firmware 5.38(ABFW.0) 28/03/24. I configure a VPN Access 2FA using email internal server (Exchange 2016).
In maintenance/Diagnostics/Network Tool, I check "test email Server" with a setting that works, I receive test email on Outlook.
Using this tested configuration, in Configuration/System/Notification/Mail server for 2FA, users can open VPN Tunnel, but they don't receive any email for confirmation.
In log, I don't see any email sent for authentification.
Any idea ?
  • Zyxel_Cooldia
    Hi @jetinfo,
    Are you saying that based on the same settings, V5.37 works, but after updating the firmware to V5.38, you are unable to receive any 2FA emails?
  • jetinfo
    jetinfo Posts: 2
    Hi Cooldia,
    No same thing with 5.37.
    We had a similar problem on june last week. A specific firmaware was sent at thius time:
    https://www.dropbox.com/s/o6bnmmuzmw8xd1h/536ABFU2ITS-23WK23-r109880.zip?dl=1
    PeterUK Posts: 4,446 image  Guru Member
    edited April 2024
    Testing here locally with FLEX200 V5.38 all is fine by a IKEv2 Enable Extended Authentication Protocol/Server Mode
    Can you do a check on a user by changing them to limited-admin this will show send code click that and see if you get a EMail
