Not able to use Zywall in routeing
USG FLEX 200H V1.20(ABWV.0)
so just a double post of this just under a better name
I want Zywall to send HTTP/HTTPS out on a given VLAN 443 to my USG40 which V1.10 did
FLEX200H
External VLAN443
IP 192.168.44.8
gateway 192.168.44.2
hits look like it work but it don't work
update if I have one External WAN online VLAN443 then it works but if I plug in say WAN2 ge2 it stops working after some time
Hi @PeterUK,
Can you send me the latest configuration in PM
sent
So if I have VLAN443 online only Zywall two way traffic fine
If I have VLAN443, WAN2, WAN3 online with routing rule for Zywall to go out VLAN443 I get this
I'm not sure but is it possible to have packet look fine without the added FCS for the routing rule for Zywall? And my modem to drop it without a FCS?
Any update on this please?
- 441 Beta Program
- 293 Service & License
- 461 News and Release
