Been seeing this error
most on routing and NAT rules moving them about
Hi @PeterUK,
We will have fix in next FCS. 1.30.
Thank your feedback.
Kevin
Hi @PeterUK ,
What's the firmware version.
And please post the result of the following CLI:
> diff running startup
its on the new firmware
USG FLEX 200H V1.20(ABWV.0)
login as: admin
Keyboard-interactive authentication prompts from server:
| Password:
End of keyboard-interactive prompts from server
0> diff running startup
0>would you like me to send you the config? its over 200KB
Hi @PeterUK ,
I tested those action in your 200H, but there's no error message pop up
1)Took Polciy Route #2 move to rule 3
2)Took NAT Rule#6 move to rule5
Please kindly correct me if I have wrong steps.
Thank you
I did remove some rules so that might have something to do with it I was seeing the error for a rule move bottom to top
OK, so the error message is gone.
Please kindly inform me when you see it again.
Thank you
Have made it happen again under a new error
I now have 28 routing rules If try to move bottom rule to top I now get error
on reboot with 28 rule you can move 28 to 1 but add one more rule for 29 to 1 you should get error or add mor rules move them to the top until you do run into this error
I moved rule19 (the last) to the top.
But there's no error. Could you try again within 04-18 firmware.
Thank you
No you need more rules over 28 to make this happen and I only just got it on 04-18 firmware
I will make some more rules and let you test
Ok move 29 to the top
Thank you ,
Now can see issue in your site. Please help stay the symptom for us.
- 398 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 83 Nebula Status and Incidents
- 5.2K Security
- 99 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 923 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 212 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2.1K FAQ
- 1K Nebula FAQ
- 445 Security FAQ
- 238 Switch FAQ
- 213 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 142 Service & License FAQ
- 72 About Community
- 62 Security Highlight
