Up time UI not loading in V1.20
PeterUK
PeterUK Posts: 4,485 image  Guru Member
edited April 2024 in USG FLEX H Series
USG FLEX 200H V1.20(ABWV.0)
Everything now has spinning circles in UI then I see this:
After 10mins the UI loads fine my site to site on USG60W show its not connected then if I go to IPSec VPN on FLEX200H the UI goes back spinning circles would you like to remote check it?
  • Zyxel_James
    Zyxel_James Posts: 809 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Sure, please provide remote access via private message, I will look into this, thanks.
    Moreover, did you collect anything like console log or diaginfo after you noticed the issue?
