how can I forward local IPs?
Arctx
Arctx Posts: 3  Freshman Member
that's the problem
I set up a VPN, everything works, I connect to the network and access the Internet using the company’s public IP.
The problem is that the IP VPN doesn't see the local IP and I can't configure it so that the IP range 192.168.51.1/24 sees the IP range 10.10.3.1/24.
how it's done in Zyxcel
  • Arctx
    my problem was this: when I connected via VPN, my PS accessed the Internet from the office IP, but my PC did not see the office local network, could not connect to the printer to our server, etc. If you have the same problem, here are solutions for Zyxcel USG series (my Fireval is not connected to Nebula account)
    it will be easier and more practical if you look at the configurations from the screenshots
    I hope this helps you
    01.jpg 02.jpg 03.jpg 04.jpg 05.jpg 06.jpg 07.jpg 08.jpg 09.jpg 10.jpg 11.jpg 12.jpg 13.jpg 14.jpg 15.jpg 16.jpg 17.jpg 18.jpg
    PeterUK Posts: 3,799  Guru Member
    You need policy control rule from VPN zone to LAN zone of 10.10.3.1/24
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,320  Zyxel Employee
    Hello @Arctx
    Welcome to the Zyxel community. Please check the Monitor > Log to see if there are any blocked messages and check the security policy to ensure the VPN IP range 192.168.51.1/24 can access the internal LAN IP range 10.10.3.1/24.
  • Arctx
    thanks for the answer, I'll check it and write here
  • Zyxel_Jeff
    OK, got it.
  • I am also facing an IP issue with many websites. I've tried using a VPN, but it didn't work either. I urgently need to make my assignment that was due yesterday, and I need to do a lot of research for it. However, this IP issue is causing problems for me. Could you please provide any suggestions on how to resolve this IP issue?
  • To forward local IPs generally is not a big issue and I usually do it by checking the router settings and searching for the port forwarding section. My next step is to type in the local IP address of the device whose port I want to forward, as well as the fields for the port numbers. In other words, that makes a possible for the device within my local network to be accessed by any incoming internet traffic. On the other hand, I am an excellent planner and do not panic under any circumstances. For instance, I devise a strategy to manage my time effectively and can even hire experts to take my nursing exam for me if I can’t do it myself.
  • Arctx
