Site-to-site tunnel
Zolik
Zolik Posts: 4
We bought USG flex 100 into our office and we added it to the nebula.
Now, we need to setup site-to-site tunnel into our datacenter. On nebula site we have network 10.5.1.0/24 and in datacenter we have subnets 10.1.4.0/24 and 10.8.0.0/23. I need to have both networks from datacenter connected to the nebula device in our office, but nebula can't write two subnets to the remote networks.
In datacenter I have kerio router and Debian server, which has installed strongswan, so I can connect nebula to one of them. It doesn't matter, which of them it will be…
Do you know, how to do it?
    PeterUK Posts: 3,892  Guru Member
    Do two site to site for each subnet
  • Zolik
    Zolik Posts: 4
    It doesn't work for me. When I create second tunnel on nebula side for second subnet from datacenter, works only one network…
  • mMontana
    mMontana Posts: 1,432  Guru Member
    On "not nebula devices" If i need to connect one than more subnet i create more connections on the same gateway.
    Site 1: 192.168.10.0/24, 192.168.11.0/24
    Site 2: 192.168.1.0/24, 192.168.6.0/24
    on both sides, only one gateway for site.
    Site 1: connection from 192.168.10.0/24 to 192.168.1.0/24, from 192.168.10.0/24 to 192.168.6.0/24, from 192.168.11.0/24 to 192.168.1.0/24
    Site 1: connection from 192.168.1.0/24 to 192.168.10.0/24, from 192.168.1.0/24 to 192.168.11.0/24, from 192.168.6.0/24 to 192.168.10.0/24
    4 subnets, three conections for allow intercomunication of several subnets.
    Consider "from" local and "to" remote, as device perspective.
  • Zolik
    Zolik Posts: 4
    Excuse me, I don't understand, how you mean it…
    If you have site to site
    site to site 1
    local policy 10.5.1.0/24
    remote policy 10.1.4.0/24
    You then make another site to site 2
    remote policy 10.8.0.0/23
    Then on the other end will have
    site to site 1
    local policy 10.1.4.0/24
    remote policy 10.5.1.0/24
    and site to site 2
    local policy 10.8.0.0/23
Nebula Tips & Tricks
