XS1930-10 Access Problem
Good morning,
I have a Switch XS1930-10. My PC is connected directly to it (Port 1).
It works very well except for access:
- The switch does not respond to PING.
- I do not have access to the graphical interface.
- And the ZON tool can't find it.
On the other hand, if I do a reset via the button (or ON/OFF), everything works for a while then nothing again.
Do you have an idea to resolve the problem?
Thank you in advance for your help.
Hi @akeix,
Thanks for your feedback. I want to update you that we have found the solution and will fix this issue in the next official firmware release. You may keep an eye on
If anyone has this issue and your network uses IPv6, please disable IPv6 first.
Zyxel Melen0
Hi @akeix,
Does this mean you can do the tests below after rebooting the switch?
- Ping to the switch.
- Access the local GUI
- Find the switch on ZON tool.
In addition, please check the network adapter is correct if you cannot find the switch via ZON tool.
Zyxel Melen0 -
Hi @akeix,
Could you also share what IP address (the IP address of your switch) did you ping to?
Zyxel Melen0 -
Good morning,
I'm responding a little late because I was on vacation.
I just reset the switch.
The switch responds to the ping.
The WEB interface is accessible.
And the ZON tool finds the switch.
Hi @akeix,
I can help you check what happened from the tech support file. Could you help to collect the tech support and share it with me? Please navigate to Maintenance > Tech-support and click the download button of the "All" section.
Zyxel Melen0 -
Good morning,
This morning, I no longer had access to the switch via the WEB interface.
And the ZON tool didn't find it.
I had to reset the switch to access it.
Please find attached the requested file.
For information, I changed the switch password before making the file.
Hi @akeix,
Thanks for the tech support. I would like to confirm some details with you:
1. Could you share yhe full network topology (The gateway, switch, ap, etc…)? Since this issue looks like a switch hang, the full network topology can help us investigate this issue.
2. I notice your network has some IPv6 clients. Since we have a similar case that related to IPv6, could you help to disable IPv6 on VLAN 1 and monitor for about one week?
Thanks in advance.
Zyxel Melen0 -
I disabled IPv6 on VLAN 1.
I just have to watch for a week.
Thank you for your help.
Hi @akeix,
May I know if the switch cannot be accessed again after disabling IPv6 for one week?
Zyxel Melen0 -
Good morning,
Since I have deactivated the IPv6 option on VLAN 1, I have no more problem.
My switch is accessible each time. I checked every day with the "ZON" tool. I also tried access via the Gui interface and it also works.Thanks for your help.
Hi @akeix,
Zyxel Melen0
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
