Trunk reference incorrect
PeterUK
PeterUK Posts: 3,892  Guru Member
USG FLEX 200H V1.20(ABWV.0)ITS-m4447
Even when I remove bottom rules to have 20 rules the reference still thinks the wrong one is their the problem might be linked to this when it happens.
Been seeing this error - Page 2 — Zyxel Community
After a reboot its correct
  • Zyxel_James
    Zyxel_James Posts: 788  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Please provide the configuration, I will check if I can reproduce this symptom
    edited April 2024
    well I could send you the config but don't think it will help a I have removed some rules plus it corrects itself on reboot.
    I think how I caused it was making 29 rules move the bottom to the top to get this
    Then I made another rule that need to be moved to the top so I moved it one step at a time to not get the above error then found the reference being incorrect until I do a reboot
