Howto request: BWM for IPSec/L2TP/VPNs
mMontana
mMontana Posts: 1,468 image  Guru Member
This howto
https://mysupport.zyxel.com/hc/en-us/articles/360010431759--ZyWALL-USG-How-to-configure-BWM-QoS-on-Zyxel-firewalls
reports how to configure specifically VoIP/SIP rule for BWM. Mostly can be replicated with some other considerations for other services/applications/service group.
Fine.
What about create a proper, working and correct rule for VPNs connection? My goal is to reserve some traffic to the connections, slowing other traffic when needed.
Currently I can only reserve traffic in/out/ for in-tunnel application, but if the tunnel is "costrained" by other data flows… i cannot preserve tunnel bandwidth?
I mean.. delay downloads/uploads of file to internet might be lower priority than allow smooth experience on traffic via VPN…
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hello @mMontana
    Thank you for your further inquiry. May we know if you want to apply Bandwidth Management (BWM) for IPSec/L2TP/VPN-related traffic and prioritize those traffic when you need it?
  • mMontana
    I'd love to reserve for a specific tunnel (6 are built, with different gateways) enough bandwidth to have stable dehaviour.
    If not possible the single tunnel, at least the gateway.
  • Zyxel_Jeff
    OK, noted it. Please let us clarify it internally.
  • mMontana
    If you have any question or… explaination, feel free to ask
  • mMontana
    Up.
    Willing to share any status or possible ETA? :-)
    Thanks.
  • Zyxel_Jeff
    Hello mMontana
    I sent a private message to you, please check it. Thanks.
  • mMontana
    Up.
    via PM @Zyxel_Jeff provided me an untested way to create BWM policy rule for manage the IPSec VPN.
    However, I was not cleared to test any not tested/official solution; I was not glad about that, however… I'm waiting for a Zyxel tested/official howto for create this kind of BWM rule
