Howto request: BWM for IPSec/L2TP/VPNs
This howto
reports how to configure specifically VoIP/SIP rule for BWM. Mostly can be replicated with some other considerations for other services/applications/service group.
Fine.
What about create a proper, working and correct rule for VPNs connection? My goal is to reserve some traffic to the connections, slowing other traffic when needed.
Currently I can only reserve traffic in/out/ for in-tunnel application, but if the tunnel is "costrained" by other data flows… i cannot preserve tunnel bandwidth?
I mean.. delay downloads/uploads of file to internet might be lower priority than allow smooth experience on traffic via VPN…
Hello @mMontana
Thank you for your further inquiry. May we know if you want to apply Bandwidth Management (BWM) for IPSec/L2TP/VPN-related traffic and prioritize those traffic when you need it?
I'd love to reserve for a specific tunnel (6 are built, with different gateways) enough bandwidth to have stable dehaviour.
If not possible the single tunnel, at least the gateway.
OK, noted it. Please let us clarify it internally.
If you have any question or… explaination, feel free to ask
Up.
Willing to share any status or possible ETA? :-)Thanks.
Hello mMontana
I sent a private message to you, please check it. Thanks.
Up.
via PM @Zyxel_Jeff provided me an untested way to create BWM policy rule for manage the IPSec VPN.
However, I was not cleared to test any not tested/official solution; I was not glad about that, however… I'm waiting for a Zyxel tested/official howto for create this kind of BWM rule
- 221 Nebula Ideas
- 609 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
