Trunk reference incorrect
PeterUK
USG FLEX 200H V1.20(ABWV.0)ITS-m4447
Even when I remove bottom rules to have 20 rules the reference still thinks the wrong one is their the problem might be linked to this when it happens.
Been seeing this error - Page 2 — Zyxel Community
After a reboot its correct
Please provide the configuration, I will check if I can reproduce this symptom
well I could send you the config but don't think it will help a I have removed some rules plus it corrects itself on reboot.
I think how I caused it was making 29 rules move the bottom to the top to get this
Then I made another rule that need to be moved to the top so I moved it one step at a time to not get the above error then found the reference being incorrect until I do a reboot
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
