Usg flex 500 loop
Hi, I'm having trouble configuring multi vlan on lan groups. As you can see from the image I have set everything on different vlans, but as soon as I connect 2 LAN cables (p4 and p5) on port 1 and 2 of the switch, everything goes in a loop. How can I solve it?
Firewall USG FLEX 500
SWITCH GS1920-24HP
You may have a check P1 & P2 port setting on switch, and have a try to disable "Management control" function from these ports and make sure if it helps.
- 212 Nebula Ideas
- 548 USG FLEX H Series
- 341 Security Ideas
- 295 Service & License
- 469 News and Release
