Usg Flex 200 - Failover with trunk
I set up a failover using trunk as explained in the tutorials.
It works fine when I test by physically unplugging the wan1 ethernet port (2)
But if I only disconnect the cable side of the cable modem, the failover on wan2 stops after a few seconds, and the only difference I see in the log is an entry msg="a connection timeout occured" cat="Myzyxel Dot Com" .
Any idea ?
8.8.8.8 in the connectivity check solves the problem…
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
