NAT -- USG FLEX 700H
YanShadowGT
YanShadowGT Posts: 22 image  Freshman Member
Good day, I have a problem with the NAT option of my USG FLEX 700H, I have created 19 rules of which they are applied randomly when I restart the device, some work and others do not, I restart again the USG FLEX 700H, the rules that did not work Now they already work and the ones that were already working stop doing so, it is totally random, it is reflected in the logs as if the rule did not exist since it does not detect it as DNAT, it simply goes to the default rule where it drops the package. This started happening to me in the new version 1.20. What can I do so that all the rules are applied? I hope for your help.
And it's not that the rule is wrong because as I explained, I restart the firewall and this rule starts working, but another random rule stops working.
