Zyxel AP with Zyxel WIFI Extender....
I have a Zyxel BE1100 wifi access point as I do not want to use the wifi capability on my router. I have a dead zone in the back of my house and I bought the AX1800 wifi extender as a simple solution.
Why is that no matter what I do, I cant add the AX1800 to Nebula nor can i get it to act as a repeater for the SSIDs managed by the BE1100...
Please help i feel like im getting dumber by the second...
Best Answers
To register your device to Nebula Control Center, please refer to the following article for instructions:
Once you have successfully registered the devices to a Nebula site, you can follow this guidance to set up a smart mesh:
If you encounter any further issues or require additional assistance, please enable Zyxel Support and let us know the problem you're facing.
Kay
Each device utilizes different mesh technologies such as WDS, ZyMesh, Smart Mesh, and others. It's important to note that these different mesh systems are not always compatible with each other. To extend your wireless coverage using mesh connections, it's advisable to choose an access point that supports the same mesh technology as your root AP.
In Nebula cloud mode, we establish mesh connections using Smart Mesh technology. To find models that support Smart Mesh, you can explore the range of access point models offered on our website:
If you have any further questions or need assistance, feel free to reach out.
Kay
Kay
Lol.
Dont worry i have returned the Zyxel products as they have sudo technical barriers.
Kay
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
