Content Filter on USG Flex100 block business website
Hi all,
Recently, our user not able to visit one of business website normally. However, I cannot found any error log from flex100. Below is the website which is categorised as "Business"
" . We only see the error page without any warning. Even I manually add its ip (152.199.39.108) into "Trusted Web Sites" under Web Content Filter. Should I miss something? Tks.Accepted Solution
The issue from the website block by wildcard domain object.
Kindly feel free to contact us again if any issue. Thank you
Add *nortonrosefullbright.com to Trusted Whitelist and make sure under the Profile Management> Custom Service, you have Enable Custom Service selected and Check common Trusted / Forbidden list.
Thanks Electsystech, I've did what you suggested , however it still doesn't work. Even I use Guest Zone which not apply any "content filter" policy.
Hi @arthurkk ,
Greeting forum, May we have remote session to check the issue ?
Please find the inbox .
Thank you
Hi Kevin,
I just found only one of our office not able to reach that website. I will check with our ISP first. Thank you so much.
Kevin,
Thank you so much. The problem has been solved.
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
