lost Private Encryption Key
AdminSys
AdminSys Posts: 39 image  Freshman Member
First Comment Eighth Anniversary
there is any way to recover Private Encryption Key from saved configuration?
  • bbp
    bbp Posts: 70 image  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    Not from config file. You have to ftp in device. Certificates and private keys are stored in 'cert' directory. Private keys have 'prv' extension.
  • bbp
  • AdminSys
    This files remain after device reset? can I get the key from this file?
  • bbp
    Yes, if you hold the reset button for less than 30 seconds.
    Not sure if you hold it for longer than 30 (complete device reset to factory defaults). Didn't test that.
