No traffic flow through site-to-site IPSec VPN tunnel
RaphaelOIiveria
Hi I deployed the USG110.
All deployment was ok, but when a configured VPN site-to-site using IPsec the tunnel connect but the traffic through tunnel not is allow.
The solution was disable Control Policy, but this solution disable all rules and the traffic bitween VLANs is permmit.
I need that VPN traffic to be allow and the Policy Control enable.
Anymore had this probleme?
The VPN tunnel just deal with the routing of the traffic goes to.
You need to set the firewall rules to allow the traffic pass to.
Here the steps that you can check,
1. check the ZONE of the VPN tunnel.
2. check the security policy rule settings.
3. Add the rules to allow traffic for to and from the VPN tunnel.
6
6 -
Hi.
I resolved the problem.
Whent I started the deployment i removed all default rules, include the rules that allow the traffic from VPN to ZyWall.
When i recreated the rule the traffic was normalized
Thanks all.
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
