Content Filter on USG Flex100 block business website
arthurkk
arthurkk Posts: 9
Hi all,
Recently, our user not able to visit one of business website normally. However, I cannot found any error log from flex100. Below is the website which is categorised as "Business"
" https://www.nortonrosefulbright.com/ " . We only see the error page without any warning. Even I manually add its ip (152.199.39.108) into "Trusted Web Sites" under Web Content Filter. Should I miss something? Tks.
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 897  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    The issue from the website block by wildcard domain object.
    Kindly feel free to contact us again if any issue. Thank you
  • electsystech
    electsystech Posts: 48  Freshman Member
    First Answer First Comment Friend Collector Fifth Anniversary
    Add *nortonrosefullbright.com to Trusted Whitelist and make sure under the Profile Management> Custom Service, you have Enable Custom Service selected and Check common Trusted / Forbidden list.
  • arthurkk
    arthurkk Posts: 9
    edited May 2024
    Thanks Electsystech, I've did what you suggested , however it still doesn't work. Even I use Guest Zone which not apply any "content filter" policy.
  • Zyxel_Kevin
    Hi @arthurkk ,
    Greeting forum, May we have remote session to check the issue ?
    Please find the inbox .
    Thank you
  • arthurkk
    arthurkk Posts: 9
    Hi Kevin,
    I just found only one of our office not able to reach that website. I will check with our ISP first. Thank you so much.
  • arthurkk
    arthurkk Posts: 9
    Kevin,
    Thank you so much. The problem has been solved.
  • Zyxel_Kevin
