Core switch configuration kiya he par power supply jab down ho gya tabhi zexyl switch default mode m
Hi @Chirag,
XGS4600 does not have an automatically save configuration function, you have to manually save the configuration before rebooting it.
You may click the Save button on the top menu. Which is the C part of the screenshot below:
If there still is a problem, please clearly describe your problem. The title has a word limit. You cannot enter your question is the title when it is a long story.
Zyxel Melen0
Hi @Chirag,
Could you share which model is your switch? If your switch is a GS19XX or above model, please know that you must manually save the configuration. You can click the save button on the top right menu to save configuration.
Here's an example of V4.80 firmware:
Zyxel Melen0 -
; Product Name = XGS4600-32F
; Firmware Version = V4.70(ABBI.4) | 10/13/2022
; Service Status = Not Licensed
; SysConf Engine Version = 1.2
; Config last updated = 04:03:07 (UTC+05:30) 2020-01-02
;; slot 1 type XGS4600-32F
;; slot 2 type XGS4600-32F
stacking priority 30
clv
vlan 1
name SW_MGMT
ip address 172.16.0.1 255.255.255.0
ip address 192.168.1.1 255.255.255.0
ip address default-gateway 172.16.0.2
exit
vlan 3
name ZONE-A2
ip address 172.16.1.129 255.255.255.128
exit
vlan 4
name ZONE-B
ip address 172.16.2.1 255.255.255.128
exit
vlan 5
name ZONE-B2
ip address 172.16.2.129 255.255.255.128
exit
vlan 6
name ZONE-C
ip address 172.16.3.1 255.255.255.128
exit
vlan 7
name ZONE-C2
ip address 172.16.3.129 255.255.255.128
exit
vlan 8
name ZONE-D
ip address 172.16.4.1 255.255.255.192
exit
vlan 9
name ZONE-A
ip address 172.16.1.1 255.255.255.128
exit
vlan 10
name DATA
ip address 172.16.10.1 255.255.255.0
exit
vlan 11
name WIFI
ip address 172.16.11.1 255.255.255.0
exit
vlan 12
name IP_PHONE
ip address 172.16.12.1 255.255.255.128
exit
vlan 13
name SPEKER
ip address 172.16.12.129 255.255.255.192
exit
vlan 14
name DISPLAY
ip address 172.16.12.193 255.255.255.240
exit
vlan 15
name command-spk
ip address 192.168.10.1 255.255.255.0
exit
interface route-domain 172.16.0.1/24
exit
interface route-domain 172.16.10.1/24
exit
interface route-domain 172.16.11.1/24
exit
interface route-domain 192.168.1.1/24
exit
interface route-domain 192.168.10.1/24
exit
interface route-domain 172.16.1.1/25
exit
interface route-domain 172.16.1.129/25
exit
interface route-domain 172.16.2.1/25
exit
interface route-domain 172.16.2.129/25
exit
interface route-domain 172.16.3.1/25
exit
interface route-domain 172.16.3.129/25
exit
interface route-domain 172.16.12.1/25
exit
interface route-domain 172.16.4.1/26
exit
interface route-domain 172.16.12.129/26
exit
interface route-domain 172.16.12.193/28
exit
interface vlan 1
ipv6
ipv6 address dhcp client ia-naexit
interface port-channel 1/1
switchport mode trunk
exit
interface port-channel 1/2
exit
interface port-channel 1/3
exit
interface port-channel 1/4
exit
interface port-channel 1/5
exit
interface port-channel 1/6
exit
interface port-channel 1/7
exit
interface port-channel 1/8
exit
interface port-channel 1/9
exit
interface port-channel 1/10
exit
interface port-channel 1/11
exit
interface port-channel 1/12
exit
interface port-channel 1/13
exit
interface port-channel 1/14
exit
interface port-channel 1/15
exit
interface port-channel 1/16
exit
interface port-channel 1/17
exit
interface port-channel 1/18
exit
interface port-channel 1/19
exit
interface port-channel 1/20
exit
interface port-channel 1/21
exit
interface port-channel 1/22
exit
interface port-channel 1/23
exit
interface port-channel 1/24
exit
interface port-channel 1/25
name FIREWALL
switchport mode access
exit
interface port-channel 1/26
name EPBX
switchport access vlan 12
exit
interface port-channel 1/27
switchport access vlan 3
exit
interface port-channel 1/28
exit
interface port-channel 1/29
exit
interface port-channel 1/30
exit
interface port-channel 2/1
exit
interface port-channel 2/2
exit
interface port-channel 2/3
exit
interface port-channel 2/4
exit
interface port-channel 2/5
exit
interface port-channel 2/6
exit
interface port-channel 2/7
exit
interface port-channel 2/8
exit
interface port-channel 2/9
exit
interface port-channel 2/10
exit
interface port-channel 2/11
exit
interface port-channel 2/12
exit
interface port-channel 2/13
exit
interface port-channel 2/14
exit
interface port-channel 2/15
exit
interface port-channel 2/16
exit
interface port-channel 2/17
exit
interface port-channel 2/18
exit
interface port-channel 2/19
exit
interface port-channel 2/20
exit
interface port-channel 2/21
exit
interface port-channel 2/22
exit
interface port-channel 2/23
exit
interface port-channel 2/24
exit
interface port-channel 2/25
exit
interface port-channel 2/26
switchport access vlan 10
exit
interface port-channel 2/27
exit
interface port-channel 2/28
exit
interface port-channel 2/29
exit
interface port-channel 2/30
exit
ip address 192.168.0.1 255.255.255.0
spanning-tree
spanning-tree priority 4096
spanning-tree 1/1
spanning-tree 1/2
spanning-tree 1/3
spanning-tree 1/4
spanning-tree 1/5
spanning-tree 1/6
spanning-tree 1/7
spanning-tree 1/8
spanning-tree 1/9
spanning-tree 1/10
spanning-tree 1/11
spanning-tree 1/12
spanning-tree 1/13
spanning-tree 1/14
spanning-tree 1/15
spanning-tree 1/16
spanning-tree 1/17
spanning-tree 1/18
spanning-tree 1/19
spanning-tree 1/20
spanning-tree 1/21
spanning-tree 1/22
spanning-tree 1/23
spanning-tree 1/24
spanning-tree 1/25
spanning-tree 1/26
spanning-tree 1/27
spanning-tree 1/28
spanning-tree 1/29
spanning-tree 1/30
spanning-tree 2/1
spanning-tree 2/2
spanning-tree 2/3
spanning-tree 2/4
spanning-tree 2/5
spanning-tree 2/6
spanning-tree 2/7
spanning-tree 2/8
spanning-tree 2/9
spanning-tree 2/10
spanning-tree 2/11
spanning-tree 2/12
spanning-tree 2/13
spanning-tree 2/14
spanning-tree 2/15
spanning-tree 2/16
spanning-tree 2/17
spanning-tree 2/18
spanning-tree 2/19
spanning-tree 2/20
spanning-tree 2/21
spanning-tree 2/22
spanning-tree 2/23
spanning-tree 2/24
spanning-tree 2/25
spanning-tree 2/26
spanning-tree 2/27
spanning-tree 2/28
spanning-tree 2/29
spanning-tree 2/30
hostname SPZP-CORE-SW
time timezone 530
timesync server 1.pool.ntp.org
timesync ntp
snmp-server contact Nikunj location KEVADIYA
dhcp server 10 starting-address 172.16.10.5 255.255.255.0 size-of-client-ip-pool 240 default-gateway 172.16.10.1 primary-dns 10.89.255.234 secondary-dns 10.89.255.235 lease day 0 hour 4
dhcp server 11 starting-address 172.16.11.5 255.255.255.0 size-of-client-ip-pool 240 default-gateway 172.16.11.1 primary-dns 10.89.255.234 secondary-dns 10.89.255.235 lease day 0 hour 60 -
Hi @Chirag,
Zyxel Melen0
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
