USG 4.33 Firmware Available - Experiences?
Updated rollout status. 4.33 seems to be upgrading from 4.31 / 4.32 devices without issue and is stable so far and no wifi issues. Crossing fingers we have a good stable build again. I have 3 more to do in the morning.0
I upgrade my firewall and he didn't come back up! sys led blinking
Tried to restore, but no luck so far
*edit* restore with the procedure in the release note0 -
@iSpeed
Regarding to your description,
Can you describe your symptom more detail and what’s the procedure you did to upgrade your firmware. Moreover, can you send me your config file in private message so that we can double if it’s config related issue?
@OTADMIN
As I updated the firmware locally, and the issue did not occur.
Can I know what version did you upgrade from?
Also, I will private message you to get more details related this case.
Charlie0 -
I have a couple of USG60Ws that I still have on FW 4.25 - when put onto 4.30 they just kept crashing and rebooting every 10-30 minutes. ZyXEL supports answer was to send a replacement (older) unit which I sent back - I now just don't trust firmware updates from them until I see lots of good reports. So I spend my time making sure the firewall rules are as good as they can be.
Look forward though to hearing of lots of positive glowing reports!1 -
@iSpeed
Does network flapping symptom happen continuously now?
Can you check on the log and share it with us?
Tks
@OTADMIN
Do you have your config file in hand? Would you private message your config file to us and we'd like to try with it locally.
In addition, can you connect the console (included in the box) to the device and dump the console message (when powering up). Then send us the console information via private message, too?
Thank you.0 -
I am having issues with both my usg310 and zywall 110. they are missing info. one I downloaded and local update and the other I did the cloud update. one was from 4.32 and the other from 4.20. screenshots attached. They are both missing info.
Did you try clearing the Browser cache?0
@dbgman
As I checked it locally, there is not display issue with firmware 4.33.
Can you clean the Browser cache or use other browser and check it again?
Charlie0 -
the V4.33 firmware works for me. i upgraded from the V4.32 patched version.
the SSL VPN bug with SecuExtender is fixed!1 -
... upgraded from V4.32 without any issues awell...1
- 432 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 115 Nebula Status and Incidents
- 6K Security
- 388 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 43 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
