SSL VPN problem
@CDS
Can you share more details or information regarding to the"Can't get authentication token"?Do you mean you can not get current status of licenses?
Charlie0 -
No. I mean the exact Problem which is described in the beginning of this thread.
The connection from the Secuextender fails with the error "Can't get authentication token".0 -
ZyWall 110 fw 4.32(AAAA.0). Same problem[SecuExtender Agent][ERROR] **** Error 0x800b010f authenticating server credentials! (0x0)[SecuExtender Agent][DETAIL] SSL session is created[SecuExtender Agent][DETAIL] Can't get authentication token(1)[SecuExtender Agent][DEBUG] SSL Connection is going to be closed[SecuExtender Agent][ERROR] user login device failed (0x0)[SecuExtender Agent][DEBUG] SSL Connection is going to be closed[SecuExtender Agent][DETAIL] Connection ends.0
I sent my configuration few days ago0
Me aswell. I struggle to now create the requested logs from Secuextender and USG at the same time .....0
@Jatama
I did received your message, but I think you forgot to attached the configuration to me. Please private message the configuration to me again.
Charlie
@CDS
I had sent you the guide about how to collect the information on Jan. 17th , had you received it since I didn’t get your feedback so far.0 -
Well,
the problem is not how to create the traces, but more how physically create both at the same time - while the PC with Secuextender is in a physically different location than the USG (otherwise I wouldn't need a VPN connection:...)
But anyway on update: I updated to V4.33 yesterday. I still can not get SSL VPN to work, but now the error is different. I'll try to dig into this now and get back when having news on this ...
I have the Same Problem by our Customer
- 441 Beta Program
- 293 Service & License
