USG Flex 200 full connect to SSL VPN with Mac iOS but dont work with Windows 11
I've a problem with Windows SSL VPN connect to USG Flex 200.
I can to connect SSL VPN with Mac iOS but cannot to work with Windows 10 or 11.
I've a USG Flex 200 (Firmware Version V5.38(ABUI.0) / 2024-03-28 02:45:56).
When i try to connect with SecuExtender 4.0.5 can to see "ACCESS FORWARD" in USG Flex 200 Log but quickly received "secuextender is connection disconnect" message.
With Mac iOS i dont have problem. SSL VPN full work. My SecuExtender Mac Version is 1.2.1.
I wait for help.
Thanks bye,
Max
Your upper device have Port forwarding ? Ensure the SSLVPN port are the same.
For example: Client connected "VPN server:10443" and your Firewall GUI is also 10043
thanks, i checked vpn ssl port and are correct.
With Mac iOS i dont have problem. I can to connect in SSL VPN.I've problem only with Windows.
I've done one test of another customer that have an USG Flex 200 and all function are correctly.
but I try to used TWO Factor authentication and now i cannot to connect in SSL VPN.What do you think ?
Thanks, Max
Hi @MassimilianoDelta ,
Greeting Forum, Please kindly share your config file any diaginfo by Private message.
Kevin
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 289 Service & License
- 461 News and Release
- 4.3K FAQ
- 97 Security Highlight
