NWA210AX | Capative Portal not working with L2 Isolation
Kilian
Kilian Posts: 4
edited May 2024 in Wireless
I’m using Nebula managed NWA210AX together with XMG1950-10E Switches and an OPNsense Firewall.
I want to host an open WiFi-Hotspot with Nebula Authentication and L2 Isolation. My problem is, that the capative portal is not working anymore when L2 Isolation is activated.
MAC-Adresses of the Guestnetwork Interface and the Gateway are whitelisted in nebula.
If I deactivate the Authentication every works fine. If I activate it, clients cannot connect to Internet and Capative Portal doesn’t show up.
HTTPs is not allowed till authentication.
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,277  Zyxel Employee
    Hi @Kilian,
    We have confirmed the issue is that L2 isolation doesn't allow client traffic when using the "Enhanced-open" security option.
    The issue you're experiencing will be addressed in the upcoming firmware update. Please stay tuned for further announcements regarding enhancements and fixes.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Kilian,
    I did a quick test in my lab and the capative portal shows up when enabling L2 Isolation. Could you enable Zyxel support and PM me your org/site name for me to check? Thanks in advance.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Kilian,
    The captive portal shows up after the client can resolve DNS. Please check your OPNsense firewall's policy rule if it allows this VLAN traffic. I used the configuration below and my clients can automatically pop out the captive portal page. And if my OPNsense firewall doesn't allow VLAN 2 traffic, the captive portal won't show up after connecting this SSID.
    Hope it helps.
    Zyxel Melen
  • Kilian
    Kilian Posts: 4
    Hi Melen,
    I double checked my Opnsense configs and everything seems to be fine.
    Until I activate both, L2 Isolation and authentication via captive portal, I can see traffic in the live logs between client, firewall interfaces and internet. If I activate both features there is no traffic anymore.
    That means:
    SSID BSKS-Hotspot with activated L2 Isolation and deactivated captive portal → works.
    SSID BSKS-Hotspot with deactivated L2 Isolation and activated captive portal → works.
    SSID BSKS-Hotspot with activated L2 Isolation and activated captive portal → doesn't work.
    Thx and best regards,
    Kilian
  • Zyxel_Melen
    Hi @Kilian,
    So "SSID BSKS-Hotspot with deactivated L2 Isolation and activated captive portal → works." means the captive portal shows up, right?
    To investigate deeper, could you allow me to access your firewall to check your firewall's configuration first? I will send you my public IP in the private message. Thanks in advance.
    Zyxel Melen
  • Kilian
    Kilian Posts: 4
    Hi Melen,
    right, that means, that the portal shows up. I can give you access to my firewall but only via teamviewer.
    FYI: I do not use VLANs on my opnsense. VLANs only configured on my switches and these are connected to phisycal interfaces on the opnsense.
  • Zyxel_Melen
    Hi @Kilian,
    Zyxel Melen
  • Kilian
    Kilian Posts: 4
    Hi @Zyxel_Melen,
    After your firmware update I can confirm, that everything is working now.
    Thanks for the great support!
