LAN Management of VMG4005-B50A
avancheri
I have a VMG4005-B50A in bridge mode. On starting the bridge with the router I cannot access anymore the management interface of the VMG from the LAN. My idea was to use two different tagged VLAN on the LAN link. One for the bridge and one the management interface. I tried by using the vlang groups but without success. And in reality the configuration of the VMG become corrupted... I it possible doing what I would like to do? Any alternative?
Thanks!
Thanks!
If the VMG4005 was set as a bridge, the LAN PC needs to set the static IP address.
For the VALN tags on the LAN port, the LAN port should support un-tagged packets.
The VLAN group is for the traffic inside the router/bridge.
This is my understanding.0 -
bump, i have the same issue, i cannot access the vmg4005 anymore if it is in the bridge mode unless i hook directly into it's lan port, what can be done about this?
Hello, i managed to get the management UI working through adding secondary WAN interface on my router:
If you can do something like this in your router it should work!
- 238 Nebula Ideas
- 6.8K Security
- 754 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
