USG FLEX 200H V1.20(ABWV.0) SNMP Issues
There is a support article titled "What OIDs do the Zyxel firewalls (USG/ATP/VPN) use to monitor key parameters?". It has OIDs for System CPU current Usage & System current session number. When I query those and compare them to the values on the 200H System Dashboard, they are significantly different.
I also get erratic responses from the 200H when querying SNMP. Sometimes it returns results immediately. Sometimes my snmp client times out with its defaults of 1 second timeouts and 5 retries. If I turn up the timeout to 10 seconds and set retries to 3, then it seems to complete all queries but is still erratic.
Best Answers
Hi @SAI_Mike,
Thanks for reporting this issue. We will check the value of USG FLEX 200H on SNMP monitor and the dashboard.
Hi @SAI_Mike,
CPU
Web GUI: The value doesn't contain fast path traffic.
SMNP "sysCPUUsage": The value contains both fast-path traffic and other traffic (ex. calculate the statistics, GUI data processing...).
Note: You can use OID (.1.3.6.1.4.1.890.1.15.3.2.21) to monitor CPU usage for fast-path traffic.Session
Web GUI: The value contains forward sessions only
SMNP "sysSessionNum": The value contains not only forward sessions but all sessions0 -
Thank you for explaining the differences.
Hi @SAI_Mike,
Hi @SAI_Mike,
CPU
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
