problemi configurazione armor g5
dsadasdas
in Home Router
Buongiorno non riesco a configurare il mio router ...Ho sbagliato qualcosa nel collegamento?
Armor behind modem?
Does Armor receive its IP address from the modem's DHCP server, or does it require a PPPoE connection to obtain an IP?
If it uses DHCP, you might consider assigning Google's DNS (8.8.8.8) to the client.
If using PPPoE, ensure to verify if the dialing process is successful or not.0 -
If it is PPPoE then there are limitations in the Armor G5, see
It does not seem like the Armor G5 can set 802.1p and 802.1q on the WAN port for PPPoE.
see section 9.4.2.
Kind regards,
Tony
- 441 Beta Program
- 293 Service & License
