[NEBULA] L2TP VPN and Windows 10
Hello everyone, is there anyone who can help me to set up an IPSEC L2TP VPN between an NSG 50 and Windows 10?
I followed this guide:
But the VPN does not connect does not work. Is there anything else to do?
Thanks for your help.
Raffaele
Hi @MGK
L2TP IPSec on Windows 10 problems are known.
A quick solution is to execute and reboot the pcREG ADD HKLM\SYSTEM\CurrentControlSet\Services\PolicyAgent /v AssumeUDPEncapsulationContextOnSendRule /t REG_DWORD /d 0x2 /f
But I suggest to read the following links:
https://superuser.com/questions/1298513/l2tp-ipsec-vpn-fails-to-connect-on-windows-10-works-fine-on-ios
https://github.com/hwdsl2/setup-ipsec-vpn/blob/master/docs/clients.md#windows
I hope it helps you.
Best regards
@MGK,
Thanks for @Alfonso.
Please refer to the following link about the similar topic.
https://businessforum.zyxel.com/discussion/1999/connection-vpn-l2tp-over-ipsec-from-windows
Hope it helps.
It works!
Thank you!1 -
Great
- 588 USG FLEX H Series
- 477 News and Release
