Average Response Time (ART) mac-table flush
WhoYouNow
WhoYouNow Posts: 3
Hi all! How can I automate the process of cleaning the mac address table. Due to the frequent use of Apple technique and the constant change of mac address, I have overflow. Where can I find the configuration in nebula?
Best Answers
  • Zyxel_Kay
    Zyxel_Kay Posts: 995  Zyxel Employee
    Hi @WhoYouNow
    Thank you for sharing your switch models.
    Currently, Nebula Cloud does not provide a mechanism for Nebula switches to automatically flush the MAC table. Generally, automatically flushing the MAC table is not reasonable as it may lead to short-term traffic forwarding issues.
    By the way, the switch defaults to flushing the port MAC when the port client does not respond for at least 5 minutes, and when the port is unplugged. However, it does not flush the table by interval automatically.
    Additionally, you can flush the MAC table via the SSH command: mac-flush [<port-num>]. For switches running firmware version V4.80 or above, you can access it remotely via the 💎 Remote SSH function on Nebula CC. For firmware versions V4.70 or below, please access SSH locally.
    Kay
    Engage in the Community, become an MVP, and win exclusive prizes! https://bit.ly/Community_MVP
  • Zyxel_Kay
    Hi @WhoYouNow
    For the switches, there is no difference between the physical real MAC address and the virtual MAC address.
    When a MAC address dynamically changes, the mechanism we mentioned will age out the MAC address from the MAC table if there is no response for 5 minutes.
    Kay
  • Zyxel_Kay
    Hi @WhoYouNow
    Could you please let us know the switch model and the firmware version you are currently using?
    Kay
  • WhoYouNow
    WhoYouNow Posts: 3
    XGS1930-28HP V4.70(ABHS.7) | 11/30/2023 (Latest)
    XS1930-12F V4.80(ABZV.3) | 10/06/2023 (Latest)
  • Zyxel_Kay
    Hi @WhoYouNow
    Kay
  • WhoYouNow
    WhoYouNow Posts: 3
    Thanks for the answer! I'm learn the problem deeper.
    Can you tell me how the equipment reacts to changing the mac addresses of Apple devices?
  • Zyxel_Kay
    Hi @WhoYouNow
    Kay
Nebula Tips & Tricks
