How to enable SNMP AP nwa50ax
I have already did it in nebula cloud, my ap were updated, but I can't use snmp
Then i try to look via cli:
Router(config)# show snmp status
active : no
port : 161
version : v2c
contact : support@zyxel.com.tw
get community : public
set community : public
trap : yes
informs : yes
trap host : none
trap community: public
wireless trap : no
I've tied comand snmp-server ebable, but nothing changed
Checked manual once again, but where no other commands
How to eneble snmp?
Hi @write4nik
At this time, the NWA50AX does not support SNMP functionality, as this model is designed primarily for home and small business environments.
However, we recognize the importance of such features for certain users and are keen to understand your requirements better, could you share more about your specific use case for SNMP on the NWA50AX?
Nami
That's very unusial than your decided snmp is an enterprise feature
That's quite old function and all other devices other vendors has it by default, even 20$ devices(nwa50 $100+)"your specific use case for SNMP on the NWA50AX? "
-That's not specific. Typical monitoring process, that's not an enterprise function like guest portal or radius etc.. why did you block monitoring function to my devices?
Hello, we have many of this devices in the field and we need SNMP for monitoring. Can You add this functionality to GUI or CLI? When I check it, that setting are here but not configurable. Thank You
Hi @write4nik and @TomasHujcakZILLION
Acknowledging the interest in adding SNMP functionality to the NWA50AX, I would like to initiate a post in the WLAN Idea section for further evaluation and consideration.
You can view and contribute to this idea in the following post:
Nami
i would liket to have snmp monitoring.
i don't understend why there is not snmp protocol
thanks Max0 -
Hi Max @MassimilianoDelta,
Please follow this Idea post and give it a vote if you'd like to see SNMP support added to the NWA50AX:
Best regards,
NamiNami
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 489 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 47 Wireless Ideas
- 284 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
