Average Response Time (ART) mac-table flush
Best Answers
Hi @WhoYouNow
Thank you for sharing your switch models.
Currently, Nebula Cloud does not provide a mechanism for Nebula switches to automatically flush the MAC table. Generally, automatically flushing the MAC table is not reasonable as it may lead to short-term traffic forwarding issues.
By the way, the switch defaults to flushing the port MAC when the port client does not respond for at least 5 minutes, and when the port is unplugged. However, it does not flush the table by interval automatically.
Additionally, you can flush the MAC table via the SSH command:
mac-flush [<port-num>]
. For switches running firmware version V4.80 or above, you can access it remotely via the 💎 Remote SSH function on Nebula CC. For firmware versions V4.70 or below, please access SSH locally.Kay
Hi @WhoYouNow
For the switches, there is no difference between the physical real MAC address and the virtual MAC address.
When a MAC address dynamically changes, the mechanism we mentioned will age out the MAC address from the MAC table if there is no response for 5 minutes.
Kay
Hi @WhoYouNow
Could you please let us know the switch model and the firmware version you are currently using?
Kay
XGS1930-28HP V4.70(ABHS.7) | 11/30/2023 (Latest)
XS1930-12F V4.80(ABZV.3) | 10/06/2023 (Latest)0 -
Hi @WhoYouNow
Thanks for the answer! I'm learn the problem deeper.
Can you tell me how the equipment reacts to changing the mac addresses of Apple devices?0 -
Hi @WhoYouNow
Kay
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 457 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
