Zyxel XGS 4600 QOS/quality of service
Good afternoon
I have XGS4600.
I need to configure QOS this way:
clients - 192.168.1.0/24, ports 1-48
server1 - 192.168.2.1, port 52
server2 - 192.168.2.2, port 52
I need to configure it so that traffic between clients and the server1 takes up no more than 40% of the bandwidth on port 52, and between clients and server2 - 100% of the bandwith. Can this be done and how? As far as I understand, you need to use the “Classifier” setting, but it’s not entirely clear how to reduce the throughput of the created classifier.
Hi @Smartqwerty
Here is an article about ACL configuration for rate limiting IP traffic that might be helpful for your situation:
Please note that bandwidth settings need to be specified with exact values rather than percentages. Could you confirm the specific bandwidth value you want to set for the 40% limit? For example, is it 400Mbps or another value?
Kay
Hi @Smartqwerty
Kay
Great, looks like this is what I need.
Yes, I wrote about percentages as an example, setting exact values is not a problem.
Can you clarify if I create 1 classifier rule, for example destination address 192.168.2.1, bandwidth 200 MBps - it will work like this:
traffic to 192.168.2.1 will be slowed to the specified value, while all other traffic will remain untouched.
Right?0 -
Hi @Smartqwerty
Once you have configured the ACL for destination address 192.168.2.1, enable metering and set the out-of-profile action to "Drop the packet". This will limit the bandwidth to the specified value for traffic to 192.168.2.1, while all other traffic will remain unaffected.
Kay
Appreciate your help, thank you!
- 242 Nebula Ideas
- 6.8K Security
- 764 USG FLEX H Series
- 385 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 323 Service & License
- 522 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
