Error NAT - USG FLEX 50 (USG20-VPN)
Hi
I have a problem, I would like all users who connect from outside with port 443 to be redirected directly to my server.
I can't because I get this error directly:
Original IP cannot be set to ANY while NAT-Loopback is activated because it might cause device unreachable.
Boys, can you give me a hand with her?
    PeterUK Posts: 4,446 image  Guru Member
    So uncheck NAT-Loopback
    or
    make a address interface WAN1 and set for External IP
