EMG2926-Q10A SMB and MacOs
I have configured SAMBA (to access a USB drive) on the router including the users and passwords but the ID and/or password are rejected when connecting (Finder/Go/Connect to server…). Using MacOS Sonoma 14.1.1. Any solution?
Hello @merge fruit, I think you should try connecting to the SAMBA server from a different device or operating system to see if the issue is specific to your MacOS Sonoma 14.1.1. This will help determine if the problem is related to the router or the client device.
-1 -
MacOS Sonoma updates help improve your Mac's stability, performance, or compatibility and are recommended for all macOS Sonoma users.
With this version, the system may not be able to recognize a USB hub connected to an external display
Anti-piracy Audio Unit plugins, designed for professional music applications, may not open or pass authentication
Applications with Java may exit unexpectedly capybara clicker
macOS Sonoma 14.4 brings new emojis as well as other features, bug fixes, and security updates to Macs. You can try again in different ways.-1
- 601 USG FLEX H Series
- 480 News and Release
