usg40 to usg flex 100: problem applying converted configuration file
copossum
copossum Posts: 14 image  Freshman Member
hi all,
I converted the configuration file from my USG40 to USG Flex 100 using the conversion tool at https://convert.cloud.zyxel.com/
The entry in "From" is USG40 (4.32 or later) and the entry in "To" is USGFLEX100 (4.60)
The conversion runs without a problem and I upload the converted file to my new USG 100 Flex.
When I apply the converted file I get the following error message:
ERROR: #configure terminal interface _ppp sfp_ppp bind wan1, System default ppp interface can not bind with other ethernet interface.
Before the error there are also a couple of warnings in the log:
WARNING: #configure terminal account pppoe OPT_PPPoE_ACCOUNT exit, Please type user.
WARNING: #configure terminal account pppoe WAN_PPPoE_ACCOUNT exit, Please type user.
What could be the problem?
cheers
    PeterUK Posts: 4,415 image  Guru Member
    You may have to use “Ignore errors and finish applying the configuration file” then check over the configuration
  • copossum
    thank you, I tried that. the device tries to apply the config file for hours, but in the end it doesn't and is not reachable anymore afterwards.
    I have to reset it to access it .
    cheers
