Password reset?
With some of my clients we are slowly replacing the old USG / VPN firewalls with the new USG FLEX H.
I notice one thing, the possibility to reset the configuration in FTP and recover it from the old partition is no longer available?
Hi ,
Please refer the following guide but now we have command “atkz -g” for resetting password .
You can perform after enter debug mode.
Hi @Alex_91 ,
Greeting Forum,
Please edit config file and remove lines from "/ object user-object admin XXXXX" , then you can reset admin password after rebooting.
For example, remove all the following lines
Thank you
clear, but to be able to access the file? (if I press the reset button it loads the default config)
Hi ,
- 441 Beta Program
- 292 Service & License
