DDNS settings not found in my FWA510
coupas
coupas Posts: 6
image  Freshman Member
Hola Zyxel,
Looking in the manual it says that DDNS should be at the DNS settings in the webui.
For me it is not.
F/w is 1.18
2024-06-06 21_54_02-.__Welcome to the Web-Based Configurator__. — Mozilla Firefox.png 2024-06-06 21_54_24-.__Welcome to the Web-Based Configurator__. — Mozilla Firefox.png
please advise
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,869
    image  Zyxel Employee
    Hi @coupas ,
    As of now, for mobile routers, Nebula provides monitoring functions and a few basic configurations only. There is no option to set Dynamic DNS.
    Additionally, the screenshot you provided is for Firewall settings, so it can only be applied to firewall models.
    Zyxel_Judy
  • Zyxel_Judy
    Hi @coupas ,
    The manual covers all mobile routers. Please refer to Table 1: Feature Differences on pages 17-18 to see supported features with each model.
    Additionally, could you share your scenario for wanting to use Dynamic DNS with the Nebula FWA510?
    Zyxel_Judy
  • coupas
    coupas Posts: 6
    I see. Okay!
    And if it is connected in Nebula, will it work from there?
  • Zyxel_Judy
    Hi @coupas ,
    Zyxel_Judy
Nebula Tips & Tricks
