Reverse AP tags
I have a few scenarios where I have 4 SSID's at a site, but a few AP's I only want to have broadcast one SSID. It would be nice if we had an option for "reverse tags", in other words, the AP would only broadcast the SSID's associated with tags.
Unless I am missing something, currently the only way to work around this is to add all of the SSID's to a tag like "All SSIDs" and assign that to every over AP.
Hi @TAPTech ,
We already have the Tag feature for AP and SSID. Please refer to this FAQ for configuration instructions:
Zyxel_Judy
Hi Judy,
Thank you but I think I was not clear in what I wanted- I would like the option for this to work backwards. I hope my example below makes sense.
Hi @TAPTech ,
Thank you for sharing your idea and example. We understand your example with the REVERSE TAGS. It means your "Garage" AP will broadcast all other Nebula SSIDs on your site, such as SSID_A and SSID_B, but will not broadcast the "voip" SSID.
However, you can achieve your goal by adding SSID_A and SSID_B into the Tags box. Could you share with us any reason why you believe you need the REVERSE TAGS feature when we already have the Tags feature?
Zyxel_Judy
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
