Why my FWA710 doesn't keep DNS servers?
Diego_Gialletti
Diego_Gialletti Posts: 5
edited June 2024 in Nebula
Hi, my FWA710 doesn't want to keep my DNS servers in "Home networking"→"my_lan_1". I've tried to set and reboot, they were still there, but after 1/2 days, when logged in i can see DNS servers of my ISP, even if is still selected "manual" with those addresses. And why i have to reselect "my_lan_1" every time i get into this section to modify settings, it still goes to visualize "default"
  • Zyxel_Judy
    Zyxel_Judy Posts: 1,938  Zyxel Employee
    Hi @Diego_Gialletti ,
    To better support you, could you share the following details with us:
    Do you mean that the "From ISP" checkbox is checked, but DNS Server 1 and DNS Server 2 still show the IP addresses you entered with the "Static" option?
    Could you share the screenshot or provide more details about this issue?
  • Diego_Gialletti
    edited June 2024
    I’m sorry, I meant the opposite, when I check Static after some days my addresses are not 8.8.8.8/8.8.4.4 but they’re from ISP with Static checked.
  • Zyxel_Judy
    Thank you for the information. We have configured the settings as you described and will monitor for any changes on our end.
    In the meantime, could you share which DNS server IP addresses you saw with the Static option instead of 8.8.8.8 and 8.8.8.4? Also, are you experiencing any service issues when the DNS server IP addresses change to the ISP's?
  • I don’t have any problems when the IP’s are switched. They switch to
    DNS 1:151.5.216.25
    DNS 2: 151.5.216.225
    Which are my isp addresses
  • here there is what I mean
  • Zyxel_Judy
    We confirm this issue, and we will resolve it in the next official firmware version, which will be announced in the NEBULA MOBILE ROUTER NEW RELEASE.
  • Patch installed, we’ll see, thanx for the support
Nebula Tips & Tricks
