MG-108 EOL? And if so, Limited Lifetime Warranty?
ObliteRon
ObliteRon Posts: 5 image  Freshman Member
edited June 2024 in Switch
I happened to notice today on the global Zyxel site, that it mentions the MG-108 is EOL:
https://www.zyxel.com/global/en/products/switch/5-8-port-2-5gbe-unmanaged-switch-mg100-series
Yet, on the same page on the US site, no mention of EOL:
https://www.zyxel.com/us/en-us/products/switch/5-8-port-2-5gbe-unmanaged-switch-mg100-series
So, is the MG-108 EOL?
If it is, how is the Limited Lifetime Warranty affected? According to the warranty article, it says it should be 5 years after the EOL announcement:
https://mysupport.zyxel.com/hc/en-us/articles/360003643980-Limited-Lifetime-Warranty
  • ObliteRon
    My MG-108 is fine, but I'm curious since it's a bit unclear.
  • Zyxel_Nami
    Zyxel_Nami Posts: 659 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate
    edited June 2024
    Hi @ObliteRon
    The EOL status of the MG-108 varies depending on the region. Therefore, it is not considered EOL in the US.
    Regarding the link you mentioned about the Limited Lifetime Warranty, rest assured that it is provided by the respective region, ensuring support for your device.
    Nami
