USG60W - Add 4G to 2 WAN
Good morning,
Does the usg60w support 3 wan?
I have 2 wan and a 4g dongle that unfortunately doesn't work, so i bought a 4G router and I would like to know if can I use the 4G router as another wan interface. To be honest i don't need the 4G as backup but I'd like to route all ftp traffic on that interface. Is it possible?
Thanks in advance,
Alberto
Thanks in advance,
Alberto
The are no physical 3rd WAN or OPT port on USG60W.
So the possible work-around is to create a VLAN interface as the 3rd WAN interface.
But that your 4G router need to support VLAN tagged on LAN.
2 -
Thanks for your reply.
Unfortunately my 4G router doesn't support any kind of VLANs.
- 441 Beta Program
- 210 Nebula Ideas
- 535 USG FLEX H Series
- 339 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
