Captive Portal NWA 1123 ACV3
Jonny20897
Jonny20897 Posts: 18 image  Freshman Member
Hi I already have two NWA 210ax accesspoints an use them for my Business to publish a guest WiFi. I usw tue captive Portal function in Nebula Cloud. Now I would also like to use a NWA 1123 ACV3 to do exactly the same thing. Are the NWA 1123 ACV3 able to publish an Captive Portal? I also own NWA 50ax accesspoints and they are not able to publish an Captive Portal.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    Hi @Jonny20897,
    NWA1123ACv3 supports the Captive Portal function. You may check the Device function table in the Nebula Help Center.
    Below is the screenshot for you to reference:
    Hope it helps.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Jonny20897,
    Hope it helps.
    Zyxel Melen
Nebula Tips & Tricks
